Onlydarryl
Mar 19, 2016Explorer
Roof AC shuts off with engine running
Hi folks,
Here's one that has been puzzling me for a while, and today I decided to trace down the cause -without much luck, but I'm getting closer. I have a 2002 Bounder, with two roof AC units. If I'm plugged into 120 A/C power, no problem, both AC units work just fine.
If I'm using the generator, and I try to use the main cabin (front) AC unit by itself, everything is good until I start the RV'S engine, and then I lose the AC cooling, and the control panel goes to red. You can imagine the problem in needing to stay plugged in, and travel at the same time.
Today I found that if I put the rear AC on low fan, while the front AC is set to cool, then the front AC starts working again with the engine running. I'm not getting the connection here between the vehicle ignition switch and the fans in the one AC unit. Both the dual thermostat and the control box (ECC?) were replaced recently due to a failure in the heating system, but this AC problem has existed long before that happened. Any educated guesses out there?
