RKW's avatar
RKW
Roof reseal options
My RV is 7 years old and could use to have a complete caulking job on the roof for the front cap, back seam, and all vents, antenna, and the bathroom skylight. I've done a complete job before on my first RV, but that was over 20 years ago. Physically, there is no way I want to attempt that now. Here is where I'm going with this: I cringe to think of the cost of this if I took it to a dealer shop and had an RV tech do it and was charged the going per hour rate. Most shops are $130.00/hour and up. Don't get me wrong here. Overall, a certified RV tech is worth every penny he earns. There is a very wide range of expertise they must possess. But not all RV work is complicated and/or technical. Some jobs are simple, but labor intensive.
Here is my question. Are there companies or outfits that specialize in resealing an RV that charge rates that are somewhat commensurate with the simplicity of the job?
Thanks.
  • Thanks guys. I'm also considering calling some "mobile" RV repair guys and asking for estimates/bids. I would think they'd charge less than a shop but would still have knowledge of the do's and don't in a reseal job.
  • jdc1's avatar
    jdc1
    Explorer II
    Like Chris says. Even a relatively responsible teenager that pays attention to detail (look at the kid's car) could do this job.
    Thanks.
    Resealing a roof, provided it doesn't have underlying leak/bubbling issues already, is a relatively easy job. I've done it on a couple of RVs myself. If you can paint a bedroom in your house, you can probably reseal your roof. Here is a pretty good description of my project:
    https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/30201452.cfm
    I see that in your post you mention physically you don't want to do the job yourself. Understood. That is probably the one barrier to doing this task as it does require you getting up on your roof, pressure washing, etc and maybe you don't want to do that.
    Possible solution: Find someone else who is reasonable to do the task for you. Perhaps even a Handyman can do the job and their rate would be MUCH lower than an RV tech. Maybe a painter could do the task for you. Perhaps the son or daughter of one of your friends or neighbors might be interested. The job involves about 3-4 hours of prep one day (including pressure washing), and then 3-4 hours on another day to seal the roof with a few coats and paint over all the seals. In total, it might be 8-10 hours of someone's time. You can probably find someone to do it for $20-40/hr which means it will cost you ~$200-$400 in labor (....instead of $1000-1500 at the RV shop).
    Hope this helps!
    Chris
Having RV issues? Connect with others who have been in your shoes.24,329 PostsLatest Activity: Oct 28, 2025
