jjrbus's avatar
jjrbus
Roof seam and leak
94 Toyota Seabreeze, Aluminum roof.
Have a tiny leak on the sidewall in the bed area over the cab. A bit of time spent with a friend, soap and water solution and a leaf blower isolates it to the roof seam under the extruded aluminum trim.
I do not see an issue fixing the leak, but noticed that the roof seam (where the front aluminum and the aluminum roof meet) is free floating and not attached to the frame. There is a good 3/8" of give in the seam area, but not at the edge. There is no evidence of water damage inside under the seam, so unlikely caused by rot. So should this seam be free floating or attached?
I was going to use tape to seal this seam but am now thinking a lap sealant like Dicor would be better, any thoughts on that?
Any input, thoughts, ideas, suggestions, opinions or wisecracks greatly appreciated. Jim
  • agesilaus wrote:
    BarneyS wrote:
    I would use the Dicor self leveling lap sealant right on the line, let it dry, and then apply 4 or 6 inch wide Eternabond tape. This should give you a long lasting, non leaking seal.
    This thread belongs in the Tech Issues forum rather than in the DIY forum so I will move it there.
    Barney
    Exactly what I was thinking that I would do. Double seal it against future problems.
    X2. Eternabond will take care of your problem. The Dicor is extra protection.
  • Does not seem very technical and I am going to Do It Myself. But Thanks : ) Jim
    Barney
  • I would use the Dicor self leveling lap sealant right on the line, let it dry, and then apply 4 or 6 inch wide Eternabond tape. This should give you a long lasting, non leaking seal.
    Barney
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
