clipper1014's avatar
clipper1014
Roof top airconditioner
Does anyone know if a Airxcel Series 48000 air conditioner can be converted to being controlled with a thermostat? Currently the unit is either on or off. If a thermostat can be installed what are the requirements for the thermostat?
  • I don't know the answer, but if you contact RVP (Airxcel) they will likely be able to answer your question. I emailed them on a replacement part number and received a thorough answer within 24 hrs. In my book that is good service in the RV industry!
  • A new upper control board for the model wall tstat AND the wall tstat and then you run the tstat wire harness(6 or 8 wire tstat wire). Your AC should have a tstat already, but I guess you have roof mount controls(knobs) and want the Fan to shut off when the compressor shuts off. The roof top multiplug will fit the RVP control board. Doug
Having RV issues? Connect with others who have been in your shoes.24,249 PostsLatest Activity: May 14, 2025
