Premieravi's avatar
Premieravi
Rooftop AC not blowing hard
Used my camper for the first time this year and currently still camping. I turned on the air conditioner on and it ran fine for awhile but when I went back in after awhile I could barely feel it blowing out the vents. I took the top off and made sure everything was clean. I turned it back on and it was blowing like normal. I went back in a few hours later and it was barely blowing again. I'm thinking that the blower motor is getting bad and it's hearing up and slowing up. Any help would be greatly appreciated. Hoping its something easy, supposed to be close to 90 the next couple of days. Thanks
  • peirek wrote:
    I had a similar problem and the coils were freezing and blocking the air flow. I could see the ice when I removed the air filters. Normally this is caused from dirty filter restricting air flow across the coils resulting in ice forming. Not so in my case. Turned out to be the evaporator temp sensor had come unclipped from the coils. I had to remove the top side cover and the housing cover to discover it. Not a normal occurrence issue but thought I would share.
    PEIREK---that is more common than you think. That very same thing happened to my A/C in my living room (window unit). (Yes even the evap temp sensor problem). Mine became unclipped too.
    I would bet that is what happened to the OP also. Maybe not the evap temp sensor, but I would bet its ICE likely dirty filter in the RV.
  • I had a similar problem and the coils were freezing and blocking the air flow. I could see the ice when I removed the air filters. Normally this is caused from dirty filter restricting air flow across the coils resulting in ice forming. Not so in my case. Turned out to be the evaporator temp sensor had come unclipped from the coils. I had to remove the top side cover and the housing cover to discover it. Not a normal occurrence issue but thought I would share.
  • Any chance that ice is forming on the condenser restricting air flow?
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 19, 2026
