How can I rid my grey tank of the rotten egg smell when I dump; it smells worse than the black tank sometimes. Any help will be appreciated. P.S. I am presently in rv park for 4 months so putting ic...
I found the same thing as above re; the hot water heater. I drain it, flush it & add as much bleach as I can get in via the drain hole. Fill it up and let it sit for a few hours run it through the water lines and them empty, flush and refill and as they say, you know who they are, voila. I usually can smell it in the water when I take a shower and it's not sulphur water. Doesn't happen often and usually happens when on well water.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
