lawrosa
Aug 27, 2016Explorer
RPO 8BO Duel Batterys on silverado
I bought a new to me truck that replaces my S10..
Astounded to find dual batterys under the hood..I have RPO code 8bo.
From what I can find this is for the camper. There is a relay that seperates the one batt from the starting batt.
Upon testing, the spare batt read 9 volts so I removed it.
Also during my tests all 7 pin connections work normal without this battery.
All this battery does is it acts like an additional battery on top of the two that I have for the camper.
So I assume this will allow me to have a third battery..
Im thinking to put a 12 volt duracell deep cylcle 75 AH batt like the camper has..
Does this sound right?
I should be able to boon dock with added power longer and get through the fall night with heater going, without waking up to batts that are under 50% discharge..
Ill have 225 AH then if I do this..
They had an AC delco 600 CCA batt in there. Funny the starting batt is the same but a 770 cca batt.
Both these batts state 63 ah on the label which is weird...
