John_Joey
Mar 13, 2015Explorer
dclark1946 wrote:Cloud Dancer wrote:
Someone please explain the advantage of self-leveling Dicor. Thanks
It is what the factory uses to seal joints on the roof so it is compatible with the original sealant
It provides a nice wide bead of the right thickness so you don't have to be too accurate putting the material down
It does not take long to apply
It is flexible
Easy to apply on top of the original as long as you clean the old sealant and roof properly
Dick
I'll also add that it is easily found when on the road
When plastic parts fail on the roof they're easier to replace then when tape was used
Price
From what I can tell it's what 100% of RV shop will use unless there is a major leak. Reason why my first instinct is that there was a roof problem when I see the other stuff on a used RV that's for sale.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
