Buckeye_Chuck's avatar
Buckeye_Chuck
Explorer II
Oct 30, 2016
Rubber roof treatment
Do you use a rubber roof treatment? I have heard that this is not necessary. DPBM roofs are used on buildings and treatments are not used on them. I have also heard that a treatment IS needed yearly. Any input would be appreciated.
  • Alpha Systems introduced EPDM rubber roof membrane in 1987 and for years has been the major supplier of this product to the RV industry. From Alpha Systems ...
    CLEANING AND MAINTAINING THE ALPHA SYSTEMS ROOF MEMBRANE
    Proper care and maintenance of your Alpha Systems roof membrane is critical for years of trouble-free performance. Normal maintenance is simple, easy and requires no special materials.
    Periodic cleaning (three to four times per year) is the primary maintenance required. Alpha Systems recommends using a non-abrasive household cleaner, such as Top Job or Spic-N-Span, and a medium-bristled scrub brush. Do not use any harsh or highly-abrasive products during cleaning. When finished cleaning, remember to thoroughly rinse the roof and sidewalls in order to remove any soap residue and to prevent streaking. CARE SHOULD BE EXERCISED WHEN WORKING ON TOP OF YOUR UNIT! THE ROOF MAY BECOME SLIPPERY WHEN WET.
    DO NOT USE ACETONE, OR ANY OTHER PRODUCTS CONTAINING PETROLEUM DISTILLATES, ON THE ALPHA SYSTEMS ROOF MEMBRANE. USE OF THESE PRODUCTS WILL DAMAGE THE MEMBRANE.
    Periodic inspection of the roof, during cleaning, is highly recommended. Check the membrane for signs of damage. Check the caulk/lap sealant used in all termination areas, and around all accessories and fasteners, for signs of cracking or voids.
    The roof membrane can be cut or punctured by sharp objects. Caution should be used when placing any articles on the roof. If damage does occur, the membrane can usually be patched.
    Alpha's membrane is quite inert and will resist weathering well. It does not require the periodic application of products to protect it from ultra-violet light or ozone. In fact, these products can often cause damage to the roof membrane.
    If you have any questions, please contact Alpha Systems at 574-295-5206.
Having RV issues? Connect with others who have been in your shoes.24,357 PostsLatest Activity: Feb 02, 2026
