TakingThe5th
Jan 05, 2018Explorer
pnichols wrote:
The main problem with in-tank fuel pumps in RVs is that if you're "way out" somewhere with your RV and that fuel pump fails, it cannot be (well, nearly impossible without access to the top of the tank from inside the RV) replaced in the field ... and even if you can get out with a cell phone ... maybe a tow truck will not come out there to get you at any price. For example, I have in mind many remote and pristine public land boondocking spots in Utah, many of which can be easily reached with a small enough non-expedition Class A/B/C 2WD RV in dry weather... but you better not have an in-tank fuel pump failure when out there.
One can carry along an extra timing belt, one can carry along flat tire changing/repair equipment, one can carry along extra engine fluids, one can carry along jacks, shovels, boards, and a massive tool kit, it's easy and inexpensive to keep engine hoses like new before trips, the engine can run without a working alternator, etc., etc.. But a failed in-tank fuel pump is a different story. In the "old days" one could carry along a spare fuel pump that could actually be installed under the hood while in the field.
The relatively simple OEM solution to this reliability/safety issue is to design in TWO in-tank fuel pumps, with both operating in parallel with each other so that if one fails the other can easily continue supplying fuel. Then compliment the dual fuel pumps with a warning light on the dash indicating that the vehicle is now operating on only one fuel pump if one ever failed.
I'd pay more for a new RV that included dual in-tank fuel pumps.
By the way, do fuel injected engines actually NEED in-tank fuel pumps ... or could a powerful enough and field-replaceable fuel pump still be mounted right at the engine for them?
It might be more practical to either upgrade the fuel tank and isncorporate some way to change the fuel pump in the field, or to add another tank with it’s own pump. My 91 Ford p/u was set up with two tanks that way from the factory.
Pumps in general seem to like pushing a liquid better then pulling the liquid which probably explains why they are in the tank. Better pressure and better volume when you push a liquid.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
