joelynExplorerOct 11, 2019RULER reading??? Need to drill a hole for a hitch pin Have the 5/8in hitch pin and need to drill a hole a bit bigger. The size I need is 2 lines after the 5/8 in on the below pictured ruler. What size drill bit ...Show More
K_CharlesExplorerOct 11, 2019You have the arrow on 1 and 11/16 which is 1 and 1/16 inch bigger then 5/8 inch. I would drill the hole 5/8
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
Related ContentRuler readings???What are you reading?EEZ reading wrongInteresting Read...12v batteries reading 14.18v
