joelynExplorerOct 11, 2019RULER reading??? Need to drill a hole for a hitch pin Have the 5/8in hitch pin and need to drill a hole a bit bigger. The size I need is 2 lines after the 5/8 in on the below pictured ruler. What size drill bit ...Show More
Nv_GuyExplorer IIIOct 11, 2019Assuming the tape measure is "normal", as in each line represents 1 16th. 5/8= 10/16 +2/16 (the two lines referenced) = 12/16 AKA 3/4"
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 24, 2026
Related ContentRuler readings???What are you reading?EEZ reading wrongInteresting Read...12v batteries reading 14.18v
