joelynExplorerOct 11, 2019RULER reading??? Need to drill a hole for a hitch pin Have the 5/8in hitch pin and need to drill a hole a bit bigger. The size I need is 2 lines after the 5/8 in on the below pictured ruler. What size drill bit ...Show More
ROBERTSUNRUSExplorerOct 11, 2019:) Hi, 21/32" is the correct size; I just had my shank re-drilled and shortened.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 24, 2026
Related ContentRuler readings???What are you reading?EEZ reading wrongInteresting Read...12v batteries reading 14.18v
