Need to drill a hole for a hitch pin Have the 5/8in hitch pin and need to drill a hole a bit bigger. The size I need is 2 lines after the 5/8 in on the below pictured ruler. What size drill bit ...
I do a lot of metal work. Those pins are usually undersize buy just a little. I would drill the 5/8 and give it a try. In AZ rust won't be an issue, so go tight and it will rattle less.
Matt
