ktmrfs wrote:
But now there are the power saving AC units from Coleman and Dometic that drop the running current by several amps, very likely enough to use one honda 2000 even at 5000ft or so. I've run a coleman power cub with a 10A running current for hours on end at 8000ft with no problems on the honda 2000.
Do you happen to now which Dometic A/C work at lower current? My A/Cs are both Dometic. The 13,500 bedroom unitis a low profile and my RV was built last Sept. I have the sheet that the manufacturer sends with the units model # that they installed but the model # they have listed for my unit does not exist. There is one unit on Dometic site that is one number off in the middle of the model # so this might be it.
