SoundGuy wrote:
Butch50 wrote:
I currently have a Yamaha 3000iseb and a Honda 2000i. I decided I didn't want to mess with the heavy Yamaha so am looking at a Honda 2000i Companion.
Your Grand Design 303RLS is one heck of a big rig :E, is even available with dual A/Cs and can be wired with 50 amp service, none of which you've detailed in your post. Nonetheless, since you apparently don't want to deal with the weight of a larger genset like your 3K Yamaha you might consider selling both it and your EU2000i and using the proceeds to buy a pair of Honda's new EU2200i which will be even more capable of powering your rig than a pair of EU2000i paralleled gensets.
Yes my Reflection has 50 amp service and has 2 A/Cs. One 15,000 BTU and one 13,500 BTU. Most of the time the only one I would want to run is the 13,500. This would be just for an overnight stop when we don't have power and to recharge the batteries. We ordered our rig with dual panes to help out a bit with A/C or heat. I also took put the puny little fan in the bathroom out and added a Maxx Air fan. When we open the windows on each sde of the bedroom the bathroom and kitchen Maxx Air pulls fresh air through the bedroom pretty good. As long as I have air moving around me I can handle pretty hot temps and my wife handles it better than I do. In the evenings we sit on our deck in the summer (it is shaded) and just have our ceiling fan on and I'm fine, this is in 90+ degree weaher in AR with the humidty.
I really don't want to go through the hassle to sell both generators as everybody basically want to steal them from you. The Yamaha has less than an hour on it and has remote electric start it just that it weights over 160#. This is just to much for me to get out of the bed of the truck by myself (at home I have a portable lift to take it out). I want to be able to take the Honda's out of the truck in case I need to go to town without the wife. I would not want her to not be able to run at least one air. Also we have our dog and there might be times we need to leave her in the trailer (now most of the time we would have power hook up for that) but for a short time I might want to run an A/C.
2 Honda 2200 would only give me a little over 3 amps of additional power. That wouldn't be worth the expense to me. My Honda 2000 that I have now only has about 5 hours on it. It has been to Alaska and back but most of the time we just didn't need air so it just took a 11,000 mile ride with us.
Thanks for everybodys responses and I'll have to start watching CL list and check with Honda if they might get any in that have been refurbished. The only problem with this is most of them are probably going to be straight 2000 and not the Companion with the 30 amp outlet. I know it is not an RV 30 but I already have the correct plug and used it when I had the Yamaha hooked up to the trailer to see if it would work.
If you read all of this thanks for you taking the time to read it. Sorry to be so long winded but it seems the older I get the more I type.
It is a nice enough day I'm going to see about unloading the front compartment and getting ready for the battery and inverter install.
