powderman426
Jul 16, 2014Explorer
Dyngbld wrote:Grumpy374 wrote:
If your going to keep your rv at your house on a permenant basis, just do it the right way one time and be done with it. Have an electrician run a dedicated 30 amp line to a new outside outlet. Your home breaker box should have several unused breaker punchouts. Just run a 30 amp breaker with a new line. Weather proof outside outlet, and now you can run anything, includung ac.
You will spend less on the materials to do it right than you will on a good quality 10 guage 50 foot extension cord.
Grumpy
This is the best solution.
Make sure the electrician understands that this is a 30 amp 120 volt circuit.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
