pacamper's avatar
pacamper
running ac or micro unit on tt while parked at home ??
How will i know if this will work ok and not burn up my ac unit, what will i need to know, volts/amp, i have a volt tester ????
Im thinking i am running off of a 20 amp receptical.
Any help would be appreciated
  • No problems running converter, fridge, and 1 high amperage appliance on 20amps, as long as you have the proper adapters and cords.
  • 20 Amp will work if the run to the panel is short and no other high draw appliances are running on the same circuit.
    I have heard of folks melting plugs when they used an extension cord to get power to their RV from a garage outlet. Make sure you only use the trailer power cord or a short heavy duty extension cord to reach the outlet.
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 20, 2025
