time2roll
Feb 14, 2017Nomad
theoldwizard1 wrote:Yes and 122 would even be better.time2roll wrote:
Verify running voltage is 108+ inside the RV and check for excessive heat at the connections.
Otherwise you are good to go.
I would be happier if it was >110V.
If the voltage measurement is posted we can comment on the actual situation.
Kill-A-Watt will read voltage very easy. Power does not need to go through the device.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
