Hi, Obviously voltage drop is going to be an issue. If I have a 20 amp 120 volt outlet, could I use #10 wire and place an autoformer at the RV end to deal with voltage drop? What about using ...
Calculations are based on only 10 amps. Have you looked into small gauge URD(underground Rural Distribution) direct burial. Yes, it is aluminum but is must cheaper. Comes in various sizes. Here is an example. #6 URD
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
