Colonel_Monk
Aug 05, 2018Explorer
MudChucker wrote:
I added a second grey tank to my elk ridge by reducing the 3 inch outlet to 2 inch and running a pipe along the bottom of the trailer up to the oem tank. I tee'd it in just before the dump valve... Idea being it would equalize between both tanks. I installed a couple Y along the way and had threaded caps on them, I made a single thread on with garden hose attachment to flush the pipe if I ever had to.. I never had to.
I bought one of those twist on blades as well and by closing that blade I could pull my black and one grey and let the liquid equalize... When I dumped them both I still had the galley tank and second grey tank to dump and rinse with.
Those are some good ideas. Water pressure to blow any clogs....
With the 2" reduction, do you find that you end up with liquid flowing to the down stream tank, and more chunks in the tank under the toilet?
CM
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
