CA_Traveler
Feb 10, 2015Explorer III
DAS26miles wrote:You'll gain some information but refer cycle time is a factor. :h
I guess I can do a test myself and run an extension cord from the fridge to the inverter and check my battery monitor to see the actual draw. I know using propane mode my total 12v amp draw is .6amps on the battery monitor, that's the fridge, thermostat CO2 monitor and other hidden parasitic drains.
There have been 2 times while camping for days in the winter where my high propane consumption almost drained the tank. I was concerned that we might run out before breaking camp. I was wondering if powering the fridge thru the inverter would work.
But my house batteries would have to be charged also..
Connect the refer to a Kill A Watt for several typical days then do the math to determine the average daily battery draw.
In the end you'll decide to not run out of propane. :B But perhaps a backup plan for a limited amount of time. :@
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
