Ron3rd
Jun 17, 2015Explorer III
SkiSmuggs wrote:Ron3rd wrote:
It's interesting that while there is a small drain when the fridge is switched to propane, there is a greater draw when the fridge is left on AUTO while running off propane. My EU2000 generator started tripping the overload circuit breaker when I turned the microwave on and I would not figure out why until I learned on this forum not to leave the fridge set to Auto when using propane. I switched it over to "gas" and no more Honda breaker-tripping. So my take away is it draws much more DC power in the Auto mode.
As BFL13 pointed out, it switches to 120V when you run the genny, so the breaker tripping was the compressor cycling on. If you don't want that, switch to the gas setting.
I seem to remember a post where someone said the fridge is more effective on propane than on 120.
Both of you are correct, I did not explain properly.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
