DiskDoctr
Sep 06, 2013Explorer
toytacoma8 wrote:
Thanks for the replies, sounds like as long as I run it for 30+ minutes at some point during the month I am probably OK to run it as needed on camping trips.
One caveat I would add for short runs. The Onans will often run rough at first, then smooth out. You want to be sure it is running smoothly when you shut it down. If not, it can be more difficult to start the next time.
A downside of not running frequently enough is the gas in the line from the tank dries out and when starting it, it must crank dry until the line is again charged before it can even try to start. You can add a priming circuit to it for under $50 to avoid hard starts (beginning of season, first day of camping trip, etc)
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
