wa8yxm
May 15, 2013Explorer III
You said he modified it to run on LP and tested it on LP but you are trying to run it on NG and it's not working, Nor would I expect it too.
This is not even close to accurate but it is a bit like trying to run a gasoline engine on diesel.. Won't work.
The part he inserted into the air flow near the choke is simply the wrong part, You should have specified NATURAL GAS as your fuel, not LP, the orifice size is quite a bit different.
