Learjet
May 15, 2013Explorer
I have had a tri-fuel gen for years and have run on all three fuels.
You should have a load block adjusment. If the load block is set for propane it will not even start on natural gas unless you enrichen the mixture with the load block adjustment. Natural gas doesn't have as many BTUs at propane, so it needs more gas.
Do you have instructions for the conversion? If you do read them please.
