SaltiDawg
May 17, 2013Explorer
sharp3 wrote:
Okay, I experimented a little with the demand regulator and found that when i slightly push the primer button on the regulator, the generator stops surging and runs smooth.
So this means that either the regulator is not working correctly or the carburetor is not producing enough vacuum to draw in adequate gas, right?
OR the hose from the regulator to the spud tube is too small in diameter to allow sufficient fuel flow.... Thus causing your load block adjustment to be impossible.
YMMV.
