railroaderExplorerDec 17, 2014Running HotI have a 350 Isc cummins engine. Had a new radiator put in and the temperature is around 225 deg. Before new radiator 180Deg. It starts to heat up as soon as I start down the road.
time2rollNomadDec 17, 2014Did you check the core rows were the same number?Did all fan shrouds etc get properly reinstalled?Did you verify coolant level?
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
Related ContentRunning Hot!Ford V10 Running hot8.1 Engine Running HotRunning hotFurnace running very hot...
