Berkyeng's avatar
Berkyeng
Running Hot!
Hi all
I purchased my 2008 Forest River Berkshire 390BH (Freightliner Chasis, 340hp Cummins 6.7L ISB) about 1 year ago. It has 52,000kms on it (I bought it at 45,000kms). For completeness related to this question, I am flat towing my 2018 Ford Explorer behind it.
Took it on its first trip (with me) over some steeper grades (Salmo, Bombi, and Bonanza Passes in southern B.C.). On the steepest sections of grade (8-ish%) I started building heat in the engine. Needle never made it to “red” and didn’t get any warnings on the dash, and the engine cooled back down within a couple minutes after coming off the grades. The rig and toad slowed to about 50kph (30mph) up these grades in 3rd gear. I do feel like I babied it a bit up these grades as well.
Thoughts on if I have a cooling problem? Outside temps were mid-20s Celsius (70s Fahrenheit) at max, even cooler at the summits.
Any advice greatly appreciated.
Thanks.
  • Thanks.
    Is there any way to access this from under the coach (knowing full well this will get me wet and dirty!). I’ve been under the bedroom once and the engine cover is so tight it took me 2 days of prying and pounding to get under the bedroom. I really don’t want to go through that again!
    Thanks.
  • Clean the front of the CAC as well as radiator. Access from bedroom or closet depending on floorplan.
    Needs to be done annually.
    A garden hose and Simple Green Extreme (will not harm the aluminum CAC)and an old pair of clothes you don't mind getting dirty is all you need.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
