TucsonJim
Oct 10, 2013Explorer II
Use a volt meter. Set it to read DC volts. Turn the car's headlights on and make sure that the tail lights are illuminated. Place the black lead of your volt meter on pin one of your seven way connector. Place the red lead of your volt meter on pin three of the seven way connector. If you are reading approximately 12-13 volts, then the problem is somewhere in your trailer wiring. If you do not have a voltage reading, then the problem is with your car's wiring.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
