dougrainer
Aug 30, 2018Nomad
Should have Freightliner chassis, you should be able to find the clearance light fuse and pull it and lights go off. Not sure if your year model has the 'ICC" light button on the dash. This is the button that truckers use to flash their clearance lights when you pass them. This system if you have it may be the cause. Doug
