dave17352's avatar
dave17352
Explorer II
Apr 30, 2013
running refer on inverter full time
Okay so now I was curious is there any harm running my refer on my prowatt sw2000 full time when camping or traveling. I have a automatic switch but I notice if the compressor is running it still flinches when the switch over takes place. So what I was curious about is if I turn off the circuit that runs the refer and the entertainment center those circuits would be running full time on my inverter. When plugged into shore power or genny running the converter charger would still run keeping the batteries fully charged and supplying the power to actually run the inverter. So my question is when running inverter while converter is supplying power to the batteries do the batteries take a hit or does it do no harm because the converter is supplying the power.
So more simply, any harm running the refer and entertainment center on the inverter full time. Will this cause any degradation of the batteries unnecessarily? I have a 60 amp 9200 series P/D converter charger.
Thanks
  • naturist wrote:
    If you are on shore power, the dual inefficiencies of turning 120 v AC into 12 v DC, then back into 120 v AC have already been pointed out, which wasted power turns into heat, which gradually will use up both converter and inverter, leading to early replacement of each.
    Into the bargain, a 2 kw inverter running a compressor style refer is going to suck a lot of power out of your batteries when not on shore power. If running down the road, your TV or MH alternator probably won't be able to keep up, so you will land with your house battery slightly discharged. Any time boondocking or not on shore power will use up battery pretty fast.
    A compressor refer uses around 650 watts when running, and around 2000 watts for a few seconds when starting up. (YMMV depending on which make and model and size is in question.) This is a 54 amp draw running, and a 167 amp draw when the compressor is starting up. This sort of load will suck your house batteries pretty fast. If you had a single group 24 battery, that load would pretty much deplete the battery in 30-40 minutes, and completely kill it in less than an hour, assuming 100% efficiency, which of course, you will not have.
    Given that your converter probably recharges your house batteries at the rate of 55 amps (or less, some are only 45 amps), while both inverter and refer are running, you will not be charging the house battery at all.
    Just for a reference I have two batteries and my refrigerator pulls about a 110 watts when running about 360 watts when starting for a few moments. It is a 10.3 cubic foot refer. I have measured these and this is accurate. I appreciate all the opinions and hope to get many more.
  • I see no harm in it although I think it would be better done with a sine wave unit. I have seen a half dozen units configured this way although the vast majority run it more conventionally...eg on shore when connected yo shore. I know the hiccup you are taking about during switch over. The way I avoid it is to turn the fridge off when doing the switchover. I do this with a remote disconnect for the AC going to the fridge. Then again I only seem to remember half the time and all is still well. :).
    Your fridge will only draw about 95 watts when running. Should you choose to do it the way you describe the converter or alternator will have no problem keeping up with this
    load.
  • If you are on shore power, the dual inefficiencies of turning 120 v AC into 12 v DC, then back into 120 v AC have already been pointed out, which wasted power turns into heat, which gradually will use up both converter and inverter, leading to early replacement of each.
    Thanks
    There is some loss going from AC to DC to AC. So you may burn say 20% more genset fuel doing it that way, and the batteries will charge more slowly, so you'll have to run the genset longer yet.
    I do it for my TV and Blu-Ray player, but that is only a 150W inverter, and I don't use a genset.
    Jim
  • While your converter is large enough that it will probably be able to keep up with the inverter draw, why add the wear & tear on the electronics of each, as well as the batteries?
    The transfer switch that Prowatt supplies is there so that you don't need to use the inverter when on shore power. The 'flitch" you describe is just the very short delay that takes place while the switch it making the transfer.
