- spud1957Explorer
spud1957 wrote:
Lets not make this more complicated for the poster than it has to be. YES you can run your 12V fridge overnight on battery. I've had the trailer sitting for 2 days with the fridge on and no major drain on the battery.
Assuming you aren't running any other major 12V appliances during this time and you have a fully charged and healthy battery.
I've been doing this for years. I go to the storage lot 24 hours before we pack the fridge. ZERO issues.
Guess I should clarify my post. I run the fridge on propane which uses minimal 12V. :? - DrewEExplorer III
MEXICOWANDERER wrote:
Question
Rv reefers can now chill and not just maintain ambient? The last Notcool I owned demanded 240 watts on battery.
A fridge on propane mode, assuming a proper installation, for sure; maybe not as quickly as a residential fridge, but they most definitely can chill and even freeze food. A three way fridge on 12V mode, probably not so much.
I couldn't find much info on it, but I think it's probable that the poster's fridge is not a three way model, in as much as they're generally uncommon these days. At any rate, they did post that they would be running it on propane as well as battery power. - MEXICOWANDERERExplorerQuestion
Rv reefers can now chill and not just maintain ambient? The last Notcool I owned demanded 240 watts on battery. - spud1957ExplorerLets not make this more complicated for the poster than it has to be. YES you can run your 12V fridge overnight on battery. I've had the trailer sitting for 2 days with the fridge on and no major drain on the battery.
I've been doing this for years. I go to the storage lot 24 hours before we pack the fridge. ZERO issues. - How much food are you putting in the fridge? If you have room fill a gallon jug (or 2) with water and freeze it at the house. Put that in the fridge and basically you have a cooler. Once you have it cooled down it shouldn't need to run much.
- DrewEExplorer IIIOvernight would be no problem at all with that setup.
A full 24 hour day at a minimum ought to be okay (not going below 50% charge on the battery) if the battery is fully charged to start and the fridge is the only load of note. Depending on the electric usage details of that fridge design, which a quick search with Google failed to turn up, it may be a few days rather than one day. - CasinojunkieExplorer
DrewE wrote:
What kind of a refrigerator--compressor-based residential refrigerator, or RV absorption refrigerator? What size and type of battery?
The RV absoprtion fridge in propane mode will easily last through the night with most any battery you'd be likely to use, needing maybe 10 Ah, give or take. A residential fridge uses a lot more electricity than the RV fridge in propane mode.
Refrigerator is a 10.5cf Norcold Model N821 12volt 1.6
I will also be using propane.
Battery is 27DC-6 purchased from Wal Mart 2/25/2020 - bikendanExplorer
Casinojunkie wrote:
How long can I run a 10cf refrigerator on house battery?
Not hooked to shore power and need refrigerator only overnight.
Battery is new 3/15/2020.
Will be using no other electricity.
Thank you.
What type of fridge is it?
2-way won't run on just battery power.
3-way will run for quite a while on battery power.
Residential won't run on battery power unless you have an inverter.
12v only probably 8 hours or so.
Make and model number of fridge would help. - LwiddisExplorer IIYou are missing all the basics! Can't even guess without weather conditions, battery AH capacity and energy use of the fridge. Do you want to run the battery dry (and ruin it) or just down to 50% or so?
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 20, 2026
