Huntindog
Mar 20, 2017Explorer
pnichols wrote:Correct, but...... If it is hot enough to need the AC, you will be inside. You cannot hear the generators over the sound of the AC.... Not sure just what the decibal reading is, but the AC makes the most noise.
Reading some of the above comments, I'm wondering if some aren't confusing "running in Eco mode" with "running at low RPM's"?
Aren't a couple of EU2000i generators supplying 1400-1500 watts to a 13.5K A/C (whenever it's compressor is cycled ON) still going to be about half way into each of their RPM ranges? If so, then you're beyond that great 53dB true idling low speed sound that the EU2000i's are famous for.
At any rate the Honda's will idle down substantially
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
