DieselBurps's avatar
DieselBurps
Running two 2000 watt generators in eco mode with AC on
Curious if this is possible or anyone has done this. Currently I can run my Coleman mach air conditioning unit in my truck camper off just one yamaha 2000 watt generator but it's not happy about it and from the sound I can tell it's maxed out. I am wondering if I were to run two 2000 watt generators in parallel could I do it with the eco throttle on? It seems like this would be possible since both generators are putting out 26 amps and given the fact I am able to start it and run the ac with just one.
  • Always run my pair of Honda 2000's in eco. Never had a problem in the last ten years.
  • When I first start my 13.5k AC, I have both Honda EU2000i generators off eco mode running wide open. After the AC has started and run for a while, I will turn on the eco, and they will idle down to where they need to be. The compressor will restart as needed without any problems.
  • When we had our pickup camper, it had a 12,000 BTU AC unit. I could run the AC unit with my 1 Honda 2000 IF I turned off the inverter breaker switch with no problem.
    If the Yamaha 2000's operate like the Honda EU2000's, there's only a minimal increase in inrush current when the units are paralleled. Yes, the continuous current output is doubled when the Hondas are paralleled; unfortunately, the inrush current only increases 10 percent, if that.
    Why? I couldn't tell you. Bottom line, a paralleled pair of Honda EU2000i's may still need to be run with the Eco mode off to start some 13.5k - 15k RV a/c units with higher LRA's (typically those with LRA's of ~60a and higher).
  • If you have a truck camper, you probably have a smaller A/C unit than a travel trailer has. My small trailer has an 8000 btu A/C unit. With my 2800/3100 generator in economy mode, I get a small blip of RPMs when it first starts, then it settles really close to idle. So if you do have a smaller A/C unit, it should work. Rent a companion (Yamaha) generator and the parallel hookup for a few hours or a day and try it out. You may have to purchase the parallel kit. But that beats shelling out big bucks for another Yamaha and finding out it doesn't work like you want it to.
  • I have a pair of Honda 2000 and I don't run in ECO. The starting of the AVC unit is quicker then the gensets can react.
    The Honda manual eludes to operate not to run ECO under certain conditions.
    I would suggest reading the Yamaha manual very closely.
    yes....since you can run on one, the other will produce enough in eco mode..
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 11, 2026
