ScottG wrote:
2oldman wrote:
OK, yes, parallel batteries might do better separated. Series, no.
Remember, the discussion is about using two chargers. Trying to use two smart chargers for either parallel or series batteries never works well if the two chargers are in parallel.
No idea where you are getting that idea from. Here are four smart chargers in parallel on a bank of three 27s in parallel, all doing just fine. You can see the total amps by adding those up--the total as confirmed on the Trimetric. That maxes out my Honda 3000 gen for VA. Can get more amps than that by using charger(s) with PF correction, but these shown do not have that.
BTW the most amps I got with multiple chargers was with two PowerMax converters (a 100 with PF correction and a 55 without)on the Honda 3000 plus solar, all set to 14.8v, which had 172 amps showing on the Trimetric. That was on a bank of two T-1275s in parallel, in parallel with two 6s in series, for a four battery bank starting at about 50% SOC.
