RoyB
May 04, 2013Explorer III
I used the air conditioner ducts that runs from one end of the trailer to the other. In my case I had ceiling mounted cabinets on both end so it was very easy to make the run. The beauty of the air conditoner runs is you have a removable register every six feet or so so it is real easy to snake the wires from register to register.
I also got to the home entertainment real easy from the inside of a center ceiling mounted cabinet.
Being a ham radio nut you can imagine what all I have running back and forth in the air conditioner ducts.
Everything out of sight.
I had one area bringing in additional OUTSIDE antenna cable down on the floor along the front wall where there was no cabinets to use for hiding cables and I used the WIREMODE wire management items from LOWES to mount along the base board height which contains the wires inside of it.
LOWES has all you need for these kinds of projects...
ALso alot of things like audio and video applications is also available in the WIRELESS MODE where no cables are needed...
Wireless speakers from your inside sound system sound great sitting outside... I think my set came from WALMART. C CRANE company makes a nice wireless transmitter that will tap into any AUDIO signal and transit it over FM radio frequency where you can tune it in from the outside using a standard AM/FM portable stereo radio... Those are pretty neat as well...
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
