jsevigny0110's avatar
jsevigny0110
RV all 4 hydraulic jacks are stuck in the up position.
RV all 4 hydraulic jacks are stuck in the up position. My emergency brakes are on, and the Control panel lights up and nothing else work, jacks wont extend. We have checked all the fuses and can't find a way to release the jacks. This is a 99 Fleetwood Bounder, 34D. Any suggestions are welcome.
Henry
  • If his jack control panel is lighting up his battery is connected. If you cannot hear the hydraulic pump running it's likely the issue...
  • Is there a hydraulic reservoir? Even with a working pump, you need fluid.
  • you need someone outside listening for the Hydraulic pump
    either the control is not working, or you have no power to the pump
  • just for fun, take brakes off move rv a few feet and try again,, don,t no a thing about them, but its a start. sounds like a safety switch is not engaged.
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
