graypark wrote:
I am early on in the buying decision for our first fifth wheel. My question is whether or not to insist on 8000lb rated axles, irrespective of the GVW of the particular rv. Should this be a "must option" or look for one with these as standard equipment.
What for? The trailer is designed as being a certain weight and able to carry more weight up to its GVWR. Getting higher weight rated axles (heavier no doubt) just eats into your available cargo weight before you hit the GVWR. If you don't trust the designer of that trailer, don't buy it.
This actually belongs in the 5er forum.
