graypark wrote:
I am early on in the buying decision for our first fifth wheel. My question is whether or not to insist on 8000lb rated axles, irrespective of the GVW of the particular rv. Should this be a "must option" or look for one with these as standard equipment.
There's more to axles than just their rating. Say you compare 6000 lb axle to 8000 lbs axle, likely to require different wheels and tires, and the 8000 axle wheels/tires may not fit on a trailer designed for 6000 lb axle wheel/tire combos. How big is this 5th wheel you are considering? Make and model? ALWAYS have to consider the GVW.
