obiwancanoli
Sep 06, 2020Explorer
First, the dilemma, then the answer... My dilemma came about regarding dimensions.
Initially, it appeared I would have trouble fitting them in, because the dimensions of the Li were larger than the battery tray - too long by about 3". Even with the 100Ah, I could only get 3 in, length-wise front-to-back, to replace my 4 flooded jars. That meant removing the tray, having it modified to fit the new Li's. Then I remembered something... these Li's can pretty much be positioned any way one chooses, absent upside down, so I measured the battery compartment, and discovered I have about 20 1/2 inches of height open to me, and at 19.1/16", standing both of the 200Ah I wanted on end, wired in parallel, they would fit just fine, as long as they were strapped down and secured to the tray... I would then have 400Ah at the core of the system.
Does anyone see an issue with this approach?
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
