swamprat 01 wrote:
kaydeejay wrote:
Simple first check.... Do you have a compass??
Hold it near each fiver wheel with the brakes applied. If it deflects, your magnets are getting power. If not, there is a wiring issue.
If you are getting power to each magnet, and the brakes ARE adjusted, then it's time to raise each wheel and check that the brake is actually working.
If there is power, but limited braking, then it's probably time to pull the hubs and see where the grease is!
X 2
Or it could be that brakes just need to be adjusted or maybe new brake shoes are needed.
