dougrainer wrote:
Jeez people, these are RV's. If you are really concerned about the construction, THEN DO YOUR HOMEWORK! If you get laminated walls(usually fiberglass/filon EXTERIOR) you do not have to worry about gaps and voids in the insulation. OHHHH!. That means COST will factor in. Maybe that is why there are CHEAP and then Medium and then higher cost RV's. YOU GET WHAT YOU PAY FOR. There is a reason that various RV's cost a lot less than others. Most people have NO CLUE. They think ALL RV's are the same and that if they can buy an RV cheaper from the dealer down the street, it is because the higher priced dealer was gouging them. They never think of how they are built and the quality. Doug
Doug - very well stated!
FWIW, some folks price shop for everything instead of value shopping for everything. You can't buy using only looks and floorplan ... you have to buy through research.
