Daughter brought a traillight TT and the converter isn't charging the battery. The previous owner said he used to attach a battery charger to the battery cables so the 12V would work in the RV. So she...
Method not recommended: Cut off plug and attach wires direct to breaker
Method 2: Add outlet. (Warning, check plug to insure it mates with outlet, My 80 amp has a 20 amp plug will not work with 15 amp outlets but does with 15/20 amp (T-Shaped Neutral) outlets which is what I suggest you add. )
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 16, 2026
