Dutch_12078
Oct 04, 2013Explorer III
olygene wrote:
Trimark should recall the Model 60-650 door lock because it has the same problem. I spent $85 to replace the old lock with a newer one and I suspect many other RV owners have done the same based on all the negative comments in RV forum.
The Tri-Mark 60-650 does not have the same cylinder issue that the Fastec has. The 60-650 fails with a broken latch bolt that prevents the door from being opened. Mine lasted 18 years though, so it was hard to feel too bad about replacing it with the new 60-1650 design. Fortunately, my coach also has a driver's door so we weren't locked out, just inconvenienced until I could disassemble the lock from inside the coach and remove the failed piece. The door could still be locked with the deadbolt though, until the replacement arrived.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
