tenbear
Jun 14, 2015Explorer
When you were trying to connect the awning LED lights did you try to reverse the polarity? LEDs are polarity sensitive. Are you sure the black wire is the positive 12v and the white is ground?
Also, did you try my earlier suggestion of measuring the voltage under load? (connected to the lights or the motor)
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
