wa8yxm
Jun 15, 2015Explorer III
You need to use a test lamp.. This is a device that looks a bit like an old fashion ice pick with a clear or colored plastic handle.. light bulb inside the handle and a wire with a clip on the end.
I had a problem here (twice) where a 12 volt circuit went dead.. Meter showed GOOD power when I unplugged everything.. Light showed.. not a thing (Completly dark) So I set about tribble shooting.
First time: Found a spot on the wire that was bad.. this is rare but it does happend.. A quick surgical removal of the bad part followed by a well soldered and sealed splice (not just insulated but sealed against moisture intrusion) and it was back to 100% Bright light.
Second time it was the crimp on lug at the end of the wire.. New lug and back in business.... Same wire both times.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
