astraelraen wrote:
Everything would work in this scenario above UNTIL I turn on the AC. The AC compressor seems to trip the GFCI (not the breaker) everytime. Maybe my compressor is bad? If I turn on just the fan it will run fine.
Anyway, looks like I purchased an electrical gremlin. I will have more info in the morning.
Don't think you bought a gremlin, just a bad AC. If possible, try and run only the AC from a non-GFCI source. See if the AC will run. If it runs, the compressor isn't bad. Maybe OK to run on a campground pedstal only. AC units have start capicators that can go bad. Some have condensate heaters.
The other thought is that maybe everything is OK and with the sum of ALL the small leakage currents on seperate circuits tripping the GFCI. In my garage, I have ONE dedicated non-GFCI receptacle just for the RV. Taking the chance that a GFCI trips when trying to keep the refeer running prior to a journey is a huge price to pay.
Most forums and blogs suggest that a non-GFCI circuit be use to power the RV. Remember, a GFCI is used to protect people, not equipment. JM2ยข...
