RV Sam wrote:
Just had a friend drop in and he said he proved this many moons ago and always uses his fridge on gas if he is paying for power.  Said propane is much cheaper and his misses swears the fridge is much better on gas.  Not sure how she measures that ??  lol.
It's difficult to measure propane used for fridge, separately from stove and furnace.  Can be anywhere from 30 to 60 lbs per month. You can measure it in summer when furnace isn't running.  Deduct ~6 lbs/month for a stove.  Single person cooking once a few days and then reheating on propane, not using oven often, needs less than  5 lbs for a stove.
I'm not using furnace, have a wall-mounted catalytic heater.
LP fridge in LP mode works the same as in 120V mode, only the heater is 120V, not a propane burner.  I don't know why it would work "much better" on propane burner.  Maybe other people could explain.
In LP mode you still use DC power for thermostat, though very little, 5-7 KW a month.
