joe0508
Jun 02, 2014Explorer
rv furnace
I was out last night and took a flashlight and looked in the exhaust of my atwood furnace.I noticed a dirt dauber nest in there.I took a tree branch and crushed it all up.They extended the full length...
joe0508 wrote:If you used a stick and then blew compressed air into the furnace, the pieces will be all over. Yes, you can get a camera and run it in there but I don't think you'll be able to vac it all out the exhaust vent.
Would it be to any advantage to get one of those endoscope cameras and run it up in there and inspect it that way?Rather than pulling the whole unit.I can get an industrial type with a stiffer cord to do the turns in the combustion chamber.That should tell me whats in there and than run a small tube with vac to suck it out.
